Discuss Roofing replacements and repair work to properties with vertical flues in the Gas Engineers Forum area at PlumbersForums.net
Can anyone turn a boiler off to work around the flue for roofing as an example, as long as a registered gas engineer carries out the required checks and certification before turning it back on?
Depending on what you're doing but if its deemed immediately dangerous if the appliance could be used then really it should be capped off by a gas engineer.
In the real world most roofers would take steps to ensure the boiler wouldn't get turned on and that everybody who could turn it on is thoroughly educated in the dangers
I would 100% get someone to check it over before its turned back on as any movement of the flue could break something and be extremely dangerous
Yes, they are removing the fuse from the spur and informing the resident not to use it until it has been checked and turned back on by the gas-safe engineer, including attaching a notice to the boiler saying do not turn it back on until it has been checked.
Reply to Roofing replacements and repair work to properties with vertical flues in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
