I ftted a Rosalind suite for a client a few months ago and I cant say I was very impressed with the quality or design, particularly the way it is installed. The loo has a plastic close coupled cistern which is bolted to the pan and then a ceramic cover which goes over the top and rests on the pan, except it doesn't rest there as the castings aren't straight so it sits on the slant and needs to be wedged up. Trouble then is it moves so you need to put a few dobs of silicon on to hold it.
The basin is wall hung and has a seperate lower pedestal/support thing which wiegh a ton so not easy to get a good fixing on thermolite walls and very fiddly to get everything connected and straight, again the castings are poor so they dont marry up very well. Impossible to get a pop up waste connected so had to use a clicker.
All in all not impressed and will avoid in the future.
