Discuss Rothenberger plasticut waste slices in the Plumbing Jobs | The Job-board area at PlumbersForums.net
anyone got em?
I love a gimmick me and was gonna tag em onto my next order with williams, I hate hacksawing and deburring waste pipe
so, are they any good?
yes and once you master the skill of using them there ace
snap them on where you like, follow the direction of the arrow but dont squeeze to begin with once you have started to turn grip it and finish the cut, any more than one turn its tracking
I've never used anything else. I can only recommend to get the set as soon as you can it makes your Plumbing life so much easier. You just need to be careful not to turn in the wrong direction the blade can snap very quick.
Just wondering if anyone of you know where to get the blades ?
done, ill let you know how I get on
Well start chopping up little off cuts
get em, used em on a old piece of 32 and they are hard to start turning but when they do... one twist and its all done
not 'arf !
I had a pair but sold them on ebay, took too much space up for what they were worth, always burried under squander in my tool box.
I use a small 6" foldable japanese saw and a pipe deburrer.
ae235
Reply to Rothenberger plasticut waste slices in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
