Discuss Running a backboiler dry in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This will sound like a silly question but bear with me please.
I have a Brossley hurcules 30b which is currently connected to a thermal store.
The thermal store is too small for what I need to run house so I am thinking of removing it.
I really like the hurcules and wondered if I drain the wrap around boiler and fill it with dry sand do you think it could be used as a normal wood stove instead of replacing it?
At present it is 22kw to back boiler and 8kw to room. I was thinking filled with sand it could be run as a conventional wood stove and give much more heat to room.
I did not want to ask Brossley as they would probably just say no as it is not how it is supposed to be ran.
Cheers
Andrew
I would say no as well. It will overheat as the bulk of the heat was disappated away from the boiler by the wet side.
I would say it'll work as boiler is probably an optional on that stove? But you may burn out the boiler eventually as not designed to be used in that way :)
Reply to Running a backboiler dry in the Plumbing Jobs | The Job-board area at PlumbersForums.net
