Discuss Running a cold feed for sink behind the back of a freestanding oven in a domestic kitchen? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rob
Is this ok, as long as run in 15mm copper, an inch away from the rear of the oven? OR are there some regs that say no? Not much choice with current layout of kitchen.
Running horizontally in 15mm copper along this wall then freestanding oven placed against the wall. Will be about an inch gap between oven and pipe
Normally you will have a pipevoid / somewhere to run the pipes so you should be fine
Go low down and why not cut a chase in the wall to get it right out of the way. I wouldn't bother plastering over it, just felt lagging and clips.
Reply to Running a cold feed for sink behind the back of a freestanding oven in a domestic kitchen? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
