Discuss salamander CT55 pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wiggers
Hi all. Im looking for a bit of advice on the above pump. Went to house today where custard had one of the above on the 22mm hot feed from a fortic cylinder to feed hot to bath and mixer shower.
What i want to know is this set up ok as fortic cyinders dont have much capacity and unequal pressures. shes had this set up for a while with no issues is this ok to replace like for like
Cheers
Thanks paul for your reply, I wasnt sure but i had a hunch so i came on here
Reply to salamander CT55 pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi all, Just a quick question. I have a log burner and a gas boiler on a dual fuel system (Central heating and Hot Water) either can do both. The...
Hello, I’ve been doing my first refurbishment is a two bed flat with a bathroom and ensuite . Learnt a lot and been grateful for input’s...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
