Discuss Salamander ESP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
HeatStar
Hi all,
Wondering if anyone can help me on this. Fitting a Salamander ESP negative head pump for a friend to convert all gravity hot feeds in the house to pumped. The question I have is this: Does a negative head pump still need a minimum head of pressure from the cold water tank? Or can the pump be sited in the loft space at the same height as the cold water storage tank? The MIs state "600mm or less possible with negative head pump"??
I have done the installation using the Salamander S flange and fitted the pump in the loft at the same level as the tank. After priming the pump with natural flow of water it then ran for a short while before shutting down and indicating air starvation via the LED display. After repeating this procedure it seems as though that when the pump runs it is drawing in air via the vent pipe - I can literally hear it sucking in. It shuts down every time after running for about 10 seconds.
Do I need to re-locate the pump into the airing cupboard below to provide a minimum head of pressure? Or is there a blockage or restriction somewhere that is causing air to be drawn in via the vent pipe? I always thought the purpose of negative head pumps was to allow installations where a head of pressure was unachievable.
Many thanks
from all the instructions Ive seen it states 600mm min! not 6oomm or less. if you drawing air in to the pump your pipework set up sounds dodgy Id expect to overflow if anything! see instructions
[DLMURL]http://www.bathroom-trends.co.uk/instructions.pdf[/DLMURL]
Hello!
The reason that you are having an issue with lock out is due to the pump being in the loft you need an Essex flange with an anti gravity loop. This means that the pump cannot get air into it at all because the none stop Essex allows for the pump to take the water from the very center of the cylinder providing air free water.
If you still have problems after carrying this out then please feel free to give us a call on 0191 516 2002
Kind Regards!
Reply to Salamander ESP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
Hi all, Just a quick question. I have a log burner and a gas boiler on a dual fuel system (Central heating and Hot Water) either can do both. The...
