Discuss Salamander rp100 tu pump advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys, do you know if this pump can operate for the use only hot water? Or does it require both hot and cold connected?
Only reason asking customers has purchased wrong pump and I only need to boost the hot supply.
Regards
I thought if it's a twin pump that there only activated by a flow switch so if I don't have a connection on the cold side and only on the hot, the cold won't be activated which won't burn out?
I may be wrong fella hopefully I am but I can’thelp remembering this question being asked revently
It is a decent enough pump make an offer and keep it back as stock.
Wouldn`t do it because they have seals and the seals in the dry chamber need to be wet to last on top of that there is only one shaft with two bearings and by only using one end chamber the shaft will be out of balance from the load causing an early death for both bearings.
Hello,
Twin pumps should always operate with water (hot and cold) running through each end of the pump. As RPM mentioned above, there are seals in the pump - To be specific, they are mechanical shaft seals, one part is static, while the other is rotary and turns with the shaft. They are designed to self lubricate from the water, so if one end is dry, they will become damaged, leading to either a leak or seized pump. If you would like to give us a call on 01915162002, we can see which pump would be the best option for you.
Reply to Salamander rp100 tu pump advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi all, Just a quick question. I have a log burner and a gas boiler on a dual fuel system (Central heating and Hot Water) either can do both. The...
Hi Folks, I need a bit of advice or help. I have a low pressure hot water system due to the Hot Water Tank being in a bedroom, not in the attic...
