Discuss Saniflo macerating toilet leak in the USA area at PlumbersForums.net
Hello, I have had this macerating toilet for several years and am now on the second pump inside it. Today water started spewing out from the tank lid where the pump is located. It seems as though the lid came loose and I couldn't re-seat it in place without jamming something between the water tank and the lid. It stopped leaking (I think) but this is obviously a temporary solution. Is this something anyone else experienced?
if there leak i just replace the lot and tell them, p..poo. paper, and nothing easle thats why its gone **** up.
no wet wipes or any thing. full stop.
Might be leaking and dripping down the back now. Most have clip in lugs to hold the lid down to the tank with a rubber seal to hold water back.
Without seeing it for myself unless you can post pictures all I can suggest is, IF the lugs are not broken, is to use a mallet but that may not work if the seal under the lid is not located as it should be.
Reply to Saniflo macerating toilet leak in the USA area at PlumbersForums.net
