Discuss Saunier Duval F30E SB Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Tym
Hi all,
New to the site and need a bit of info. My mother has the above boiler in her house & the pressure has dropped below 1 bar. There is no filling loop on boiler to refill.
The boiler only runs heating as water is heated by tank in cupboard upstairs.
How do I refill boiler?
Tym
I have had a look around the boiler. The manual says it doesn't have one but also doesn't explain how you fill it. It just says use an external filling device.
All that's under the boiler are 4 pipes (the flow & return for heating, Gas pipe & pipe that goes out through wall for bleeding) & a black valve with manual says is a drain valve.
ok trace the two big pipes, heating flow and return around the place eventually you should
find a silver braided connection from the big pipe to the cold supply. Go all detective with a torch ! that black valve might be a drain but could also be a filling point . off out now
maybe others can assist I will look later. centralheatking
Also check loft space, sometimes come across systems that were previously open vented an have been converted to sealed (pressurised) an have put a filling loop up there. If still unsuccessful try post some photos of underneath of boiler an airing cupboard set up. Good luck
I have found the filling loop. Yes its in the airing cupboard upstairs well away from the boiler.
Have got pressure to where it needs to be but boiler will not light. It starts up ok runs for a few minutes but then the light starts flashing red & comes up with F2 error on display.
Looked up on the MI’s f2 relates to an air pressure fault. Sounds like it’s time to get Gas Safe Registered engineer in as would require case removal for further testing mate.
Look on the bright side...a call out merchant would have charged you to find the elusive filling loop...so now bite the bullet and get a GSR expert in ...centralheatking
Reply to Saunier Duval F30E SB Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
