Discuss Saying hi! And asking my first question! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rob Foster told me about this forum, so here I am! I’m a capable all rounder with regards DIY. Worked on L60 engines for my sins so will have a go at most things. Signed up today, so Hi and thanks for having me!
I’ve got a quick question that might sound barmy but here goes... I’ve got a WB 35cdi Classic plus polypipe UFH wet system. Both are connected separately via two Nest Therms.
Here’s the question: should the UFH be able to fire up the boiler independently? Currently only works if I set the boiler to heat the rest of the house?
Cheers for any help you can give, Mark
hello and welcome
sounds like its not separated with port valves (s plan the system)
yes please boiler and below if theres pipework there also ufh manifold pics
Here’s the photos on my system. The Nest Heatlinks go into a junction box, which is pretty busy. The bottom heat link works just dandy and fires the boiler. The top one operates as it should but doesn’t call for fire; I think the wiring isn’t right I think? Would it help if I took the heat link cover off and photo them too? Thanks again
At a guess it is a wiring issue, if one of those zone valves goes to the under floor heating ? you have everything you need there to work each circuit separately. Shaun should be able to help you out with a diagram . Regards kop
Wired wrong or bad port valve out of the box
Ignore the hw marking on the second port valve
That’s just for your heating side
Now?
Thanks for that Shaun...I’ve attached photos of the nest heatlinks just in case something totally crazy to view. The junction box is like spaghetti junction so pointless. I’ll put that diagram in front of the plumber as soon as he rings me, let me sort it out. Thanks again for your support! Very grateful
Any chance you could take a pic inside the j box be careful as it’s live electrics
theres your fault grey wire bottom left not installed
so defo a wiring issue who ever wired need to come back
Hey Mark you never told me you worked on Chieftan Tank engines L60 you wait till we next meet fascinated Rob Foster aka centralheatking
Reply to Saying hi! And asking my first question! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
