2. A hot pipe as seen in the pic.What are you asking ? this scorch mark is it supposed to be from
1. a gas lamp during a recent fit
2. a 'hot' pipe near the problem
please advise with a piccy
centralheatking
Discuss Scorch mark on skirting board from pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
centralheatking
Yes, I have a combi boiler. I hadn't noticed the mark until I had a closer look after I could smell burning, not a strong burning smell but enough for me to look to see where it's coming from. As long as it's not going to catch fire that's the main thing.I’d guess by the pipes that you have a combi boiler? so that’s likely hot or cold domestic water. I’d say that’s never getting anywhere near scorching temp
No.Is it hot to touch?
Thats an old scorch mark from when the system was installed, nobody has re decorated since it was carried out...fear not
I can only presume from the skirting board. The boiler itself looks fine and was only installed in 2017 and it has been serviced last year and this year. I have put some Kooltherm between the pipe and wall so the pipe is a little bit further away from the skirting board now. I've also turned the temperature gauge down from 70 degrees to 30. It's goes from 20 degrees to 80 according to the manual so I think having it that high for two years hasn't helped. The Kooltherm and turning it down should do the trick. I will still keep an eye on it though.Where can you smell this burning? As others have said I doubt it’s from there.
NoDo you use a kettle to boil hot water, any scorching?
If hot water pipes could cause wood to combust then every home would be burnt downI can only presume from the skirting board. The boiler itself looks fine and was only installed in 2017 and it has been serviced last year and this year. I have put some Kooltherm between the pipe and wall so the pipe is a little bit further away from the skirting board now. I've also turned the temperature gauge down from 70 degrees to 30. It's goes from 20 degrees to 80 according to the manual so I think having it that high for two years hasn't helped. The Kooltherm and turning it down should do the trick. I will still keep an eye on it though.
Reply to Scorch mark on skirting board from pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
