Discuss Sealed system grabbing air in the UK Plumbers Forums area at PlumbersForums.net
Time to flush the system
Cleaner and drain or just hot flush and inhibitor? I think the expansion vessel maybe stretched went from one bar cold to 2.1 hot. Obviously goes from 1 to 1.4ish when still cold on pump start up.
I would add cleaner but also have a look at any towel rails sometimes they can cause bad corrosion if there cheap
Have you physically checked the pressure in the system ? it could just be a faulty gauge or partial blockage in the tube , I'd suggest and good hot flush then a chemical clean and mains water flush check then expansion vessel is charged to 0.7 -1 bar add a couple of litres of quality inhibitor before filling slowly and avoid trapping air in the system even fit manual air vents on high spots if necessary. Kop
I didn't no, I just bleed the gas/ hydrogen out. Which took the system back down to below one bar.
Hhmm was there a smell when vented did water come out? test the water there's many Kits available and we should really be doing it . I would say it needs a clean and possibly a new vessel you may possibly get away with not doing it ? , but if you're gonna be there a day why not do it and avoid another trip later your customer only has the one bill then and just gives a bit more peace of mind you've done the job best you can. Kop
Reply to Sealed system grabbing air in the UK Plumbers Forums area at PlumbersForums.net
