Discuss Sealing monobloc tap tails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I use Loctite 55 thread for sealing half-inch and similar BSP male screw-threads. But when fitting a monobloc tap with the tiny 10mm threaded tails where the Loctite thread looks too fat, should I rely on the O-ring (with a dab of silicon lube) for sealing, one turn of PTFE, a smear of Loctite 577 or what please?
Normally the o rings are fine if you want belt and braces you can apply a tiny bit of 577 but tbh not really needed
Reply to Sealing monobloc tap tails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
