Discuss Sealing side of toilet cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have fitted this brass float valve to my toilet cistern.
Obviously the inlet is the same level as the overflow pipe so it needs to be water tight.
The inlet pipe is not flexible and enters the cistern at a slight angle to the side of the cistern, the washer I used is not squishy. The result is that it doesn't make a seal.
I would say the gap is about 3mm at the top.
Can anyone give me tips on how I can make this water tight?
I might be wrong as can’t fully see it, but firstly, you need to throw away what looks like your part 1 ball cock as the water regulations does not allow them in a toilet cistern.
It has to be part 2 to prevent the risk of back syphon/contaminating the wholesome water supply.
Then you need to either raise the ball cock position by a few mm’s or lower the supply pipe by a few mm’s, this will level it out and allow a square flush connection to be made.
To raise it, try turning the backnuts around so the alignment lip isn’t forcing the ballcock down. This should allow it to be raised a few mm and there should be enough washer to cover the hole.
Or preferably, disconnect and remove ball cock, then remove 5mm/enlarge the bottom of the wood wall supply pipe hole to allow it to exiting wall a few mm lower.
Rubber washers are available it's best to place one next to the cistern then the poly one , turn the sealing nut over flat side against the poly washer and tighten , that should do it 😉👍
I have some washers 3mm thick and they look like they will do the job but I had wondered if a Plumber would use something like Plumbers Mait or silcone sealant/mastic.
I'll give the washers a go.
Thanks for the advice.
Nope to silicon / putty
I do it dry just flip your plastic nut around on the inside
Reply to Sealing side of toilet cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I have to replace the flush valve and/or the washer but unfortunately it's inside the vanity unit. The only way is removing the toilet. I...
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low...
Hello All, Was looking for some innovative ideas from you all.😊 I’m renovating a bathroom in a flat. The soil, hot & cold water pipe runs stops me...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of...
