Discuss Set fan operation switch in the Central Heating Forum area at PlumbersForums.net
Hi, here is my question: my house 's central air conditioner has gas Heater and electric A/C, which fan operation I should switch in the thermostat? gas or electric? here are the manual instructions:
Set Fan Operation Switch, Move the switch to the proper setting:
- Gas or Oil: For gas or oil heating systems, leave the fan operation switch in this factory-set position (for systems that control the fan in a call for heat).
-Electric or Heat Pump: Change the switch to this setting for heat pump or electric heat systems. (This setting is for systems that allow the thermostat to control the fan in a call for heat, if a fan wire is connected to the G terminal.
Any advice will be greatly appreciated, thanks
Gas heat depending on stat
As the ac should bring on the fan automatically if it’s been wired correctly
Reply to Set fan operation switch in the Central Heating Forum area at PlumbersForums.net
