Discuss Setting temperature control on Heatmiser Slimline in the Water Underfloor Heating Advice area at PlumbersForums.net
E
EmmaSTru
I have preformed a Factory Reset and re-calibrated the Thermostat. Can anyone tell me if I now Set the Temperature Control will that cover the total 24 hour period.
I have tried to do this and then found the stat set at 5oC hotter - not a great idea in these cash-strapped times!!
After performing a Factory Reset and re-calibrating the Thermostat, it's important to ensure that the Temperature Control setting covers the entire 24-hour period. However, based on your experience, it seems like the thermostat was set 5°C hotter, which may not be ideal, especially in financially challenging times. It's recommended to double-check the settings and consult the thermostat's user manual or contact customer support for accurate guidance.
Reply to Setting temperature control on Heatmiser Slimline in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
