Shock arrestor on cold water pressurising hot water?
View the thread, titled "Shock arrestor on cold water pressurising hot water?" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi all, new here. Spark, not a plumber.
I have a question about something at my house that's puzzling me.
Combi boiler system in a terraced house. I've had water hammer/water shock whenever something is turned off quickly, mainly the washer. I fitted a PRV just after the stopcock and reduced the incoming pressure to around 2 bars which stopped the problem but the shower (mixer shower running from the boiler) was terrible at this pressure so upped it 3 bar. Hammer/shock returns but not as bad.
Bought a shock arrestor (Altechnic diaphragm type) and fitted it just before the washer. Happy days it's cured the hammer when the washer/toilet valves shut off. Problem is when a cold water valve or tap is opened anywhere in the house there's hammer/shock coming from the hot tap side now this is when something is opened on the cold side, not shut off. Puzzled me how this is possible? Is the shock arrestor pressurising the hot water by back feeding through the boiler!?
Any ideas or help would be much appreciated.
For info the incoming pressure is 3.5 bars. It's been reduced to 3 bars now by the PRV valve. The arrestor is pre-charged at 3.5 bars.
Update: Removed the shock arrestor from the washing machine pipe and fitted it to the cold water feed to the boiler. This stopped the symptoms mentioned in the original post but started the Thud/shock when the washer/toilet was shutting off again.
I've completely removed the shock arrestor as it seemed to be causing more issues than it was solving. I've turned the washer and toilet isolators to half way and this has solved the issue of the hammer/thud/shock in the pipes.
Thanks for all the suggestions and replies.
Reply to the thread, titled "Shock arrestor on cold water pressurising hot water?" which is posted in Bathroom Advice on Plumbers Forums.
jimbo84,
jimbo84,
