Discuss Shower Door Runners Replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
Hope this is in the correct forum area.
I have a broken plastic grooved 19mm runner but it looks like the track itself could handle a double roller configuration. is it possible to just swap out the original and replace them with the correct sizes.
Another problem is that it seems the runners may have been put onto the track and slid in during assembly so is there a way of removing them without doing the same. I had thought of just bending a part of the track and simply popping them out that way and then bend it back up but obviously the place I'd do it wouldn't be a 'running' area. ? any advice would be welcomed.
I've attached 3 photos.
regards
Rocky
Reply to Shower Door Runners Replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
