Discuss Shower Pump Pulsing! in the USA area at PlumbersForums.net
Hello everyone.
Could someone please advise on a fix for this annoying problem?
I have a shower pump feeding our master ensuite which occasionally pulses once the tap or shower is turned off. This will continue to pulse until you turn the tap back on and the REALLY slowly turn it off. Or as my daughter has discovered, turn it on and off again rapidly (perhaps confusing the pump 😉) can also work.
This sometimes goes weeks or even months without issue, other times it is daily.
I have thought about installing an expansion tank but not sure if this is the right fix. Plus the pump is twin impeller so not sure whether it would be need to be tee'd across the H&C...
Thanks in advance.
I had same problem found there was slight blockage in filter/softener yoke on the spout of sink tap (debris from tank or plumbing). Unscrewed spout cleared debris and was ok.eter
Reply to Shower Pump Pulsing! in the USA area at PlumbersForums.net
