Currently reading:
single pipe heating system problems
Discuss single pipe heating system problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
i am having problems getting heat to 5 new rads on a single pipe system. the customer supplied drayton trv4's with then and already had 10mm pipe going to the 22mm single pipe. on connecting and heating up its bypassing the new rads. is there any good way around this? i have read that special designed trvs do help but worried the 10mm runs are to small bore to carry the heat. thanks
Trv's are Danfoss RA-G either 15, 20or 25
The radiators also need to be very close too the loop, swept tees are often used to help direct the flow to the rads too
Reply to single pipe heating system problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
