Discuss Sink in bedroom not draining in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a sink in the bedroom the waste pipe is connected directly to the bath waste on the other side of the wall. Sink does not drain. I have removed the trap and the pipe down to below the floorboard. There is no clogs and if I pour water directly down at any stage of the connections it drains away fine. As soon as I add the trap piece and turn on the water it doesn’t drain again unless I disconnect the pipe from the trap ??
Any ideas please
It'll be partially blocked close to where it joins the bath waste.
The blockage will be a mixture of hair, skin and soap.
You might move the blockage by filling the sink and using a plunger and the weight of the sink full of water behind it.
Alternately you may clear it with a spring waste pipe clearing tool.
CAUTION ,if you plunge there's a slight risk of blowing the waste pipe joint apart and causing a minor flood.
Reply to Sink in bedroom not draining in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
