Discuss Sink tap removal - am I missing something obvious? in the USA area at PlumbersForums.net
Hi guys.
First time poster and by all admission an enthusiastic amateur...
I am trying to replace a washer in my bathroom sink tap. Having located the pipe isolation screw, I have managed to stop the dripping but for the life of me, having removed the tap cover, cannot work out how to remove the top of the tap! I was expecting a simple screw underneath but other than a tiny hole (which may or may not lead to a tiny screw), no obvious way to remove.
I’m sure it’s a pretty old setup that may require a plumber unscrewing various nuts underneath the sink but i’m hoping there is a slim chance I’m just missing something obvious? Seems like a lot of work to just replace a perished washer otherwise.
Pictures attached to help illustrate.
Thanks in advance.
Same as rpm and snowhead.
I know I’m not adding to the thread but I just want to know if snowhead has a spare of his nice blue spanner, I could do with one with such thin jaws.
Bacho do a nice thin jaw spanner.
or you could get the 8"
Reply to Sink tap removal - am I missing something obvious? in the USA area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of...
I need to replace the double-check/non-return valve on the pipe that goes out to the back garden tap under the sink. I got the correct replacement...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
B
Need to remove the spout on a Franke Olympus tap. I have removed the hot/cold previously with an allen key and the spout kit has a 2.5mm allen key...
Bob Hope
B
I'm probably missing something obvious, would welcome any suggestions on how I get access to the washers. We have a matching bathroom suite and...
Deleted member 120897
