Discuss Sink tap replacement in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi
I am not sure whether I have posted correctly earlier today, if so please forgive me as I am trying again just in case.
I have a sink that has the basin plus another smaller basin next to it, think it is a 1/4 of the size of the main basin. The unit comes up through one hole, has 2 taps that turn and the unit can swivel to go to either basin. The taps have 4 prongs that can be turned (sorry not technical) similar to ones on Screwfix website "swirl-cascade-dual-lever-kitchen-mono-mixer-tap-chrome/470pg".
We now have to turn the cold tap quite hard otherwise it drips and we also have water collecting around the base of the neck. As it is around 12 years old it probably needs replacing.
Being rather elderly and having some arthritis I was wondering if it would be better to have the taps that are lever like (just pushing up a 1/4 turn or moving left/right quarter turn) as these may be easier for use to use.
I have looked at reviews on both screwfix and amazon and it left me with more questions as the poor reviews mention poor quality and dripping with 1 year or 2 which is not what I want (the current no name brands lasting ~ 12 years).
Are there any particular brands that are better than others to look for and what type of turn on/off mechanism is the best (the 4 prongs, lever up, lever left etc). Also is it better to go ceramic (which the current ones are) or normal washer types? I also prefer separate taps on the unit for hot and cold (as it is now) rather than just one that mixes them itself.
I am gathering the information prior to having a plumber change it out and I want to get one that will ideally outlast me.
Thanks in advance
Colin
Reply to Sink tap replacement in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
C
Hi I have a sink that has the basin plus another smaller basin next to it, think it is a 1/4 of the size of the main basin. The unit comes up...
I have a kitchen mixer tap with quarter turn levers and the cold side started dripping. I took out the ceramic valve and replaced it with one from...
Have a sink basin tap photo attached and need to replace the heads as behind they have cracked. Any idea where I can get replacement tap head...
Hi I bought a basin tap single lever. It lifts up & to the right but won’t turn to the left for hot I haven installed it yet I’ve only put it on...
I have quarter turn taps in my downstairs bathroom, the sink taps were getting a bit stiff so I replaced the insides with Flomasta 1/2" BSP...
