Discuss Smart thermostat connection in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all
My combi boiler currently has a wireless thermostat could i just buy a smart thermostat to connect to my existing receiver or do i need a new receiver to work with a smart thermostat
Thx again i honeywell smart thermostat seem quite expensive compared to others is it relatively easy to replace the receiver too mine is located just above my boiler thx again
Yes itā€™s relatively easy. If youā€™re completely unsure post photos of wiring. Just make sure you get one that supports the switching, not all are voltage free, some are mains only and if yours is extra low then itā€™ll be no good - switching comes from the boiler.
Reply to Smart thermostat connection in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
