Discuss smart thermostats for multiple zones? in the Plumbing Zone area at PlumbersForums.net
hi, I have 4 small bedsits, the heating (radiators) for all 4 is by a single Ideal Vogue c40 Gen2 boiler, I'm wanting to install a seperate smart thermostat in each of the 4 bedsits and ideally 1 in the communal area (5 thermostats in total), does anyone know of a system that will support this? cheers.
Would you want independent control of each room ?
thanks for your reply, we don't need to control each room, just each bedsit as a whole, the plumbing has been done so that each bedsit is on a seperate zone, hopefully that helps!
So each has its own port valve ?
thanks, I think each bedsit has its own zone valve, i've attached some photos . . .
Keep it simple then
Honey well 6360 for each room and a main timer
Don't forget your can't have a trv on the room rads just lock shield
Or go with a wireless prog room stat
the bedsits are going to be holiday lets and I ideally want to be able to control the heating from a phone app - then I can turn it on before guests arrive and switch it off when the bedsits are vacant. I looked at the Ideal touch connect but sadly you can only connect one thermostat! The Nest ones are too clever (and expensive) for what we need, must be a simpler alternative that just allows you to turn the heating on and control temperature (in multiple zones)?
Heatmiser system you need if wifi it's a must
Just looking at the Heatmiser Neostat, looks like a good option, presumably we can use multiple ones with the one boiler?
Yes probably need there wiring / zone centre as well but yes
Thats great, thanks!
All the bedsits have a small bathroom, open plan living room / kitchen and one bedroom, if we had one centrally located thermostat in each bedsit would that do it?
Yes but if there's a rad in the same room must be non trv controlled
What's heating the hot water ?
Reply to smart thermostats for multiple zones? in the Plumbing Zone area at PlumbersForums.net
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
We currently have the ground floor wet UFH and upstairs rads running from an unvented condensing boiler. Any advice/experience on the following...
Hoping someone knows a wiring centre that fits this requirement. I have 1 UFH zone (3 circuits) and 2 Radiator zones. Was looking at the...
Hi, I'm after some advice on converting my current CH system to Wiser smart system. In particular, looking for advice on whether I can use the...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
