Discuss Smelly hot water . Why? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just recently when I run the hot water it has started to smell why is this and how do I go about sorting it.
We have an old baxi boiler with a water tank in the airing cupboard.
What did it smell of? Has the property been vacant for some time? Has anything changed? Have you had any work done?
Check for dead birds or vermin in the header tank. Clean your header tank & flush out the pipework,make sure it has a tight fitting lid, good insulation around it to keep it cool in warmer months to help stop bacterial growth and also to stop it freezing up in the colder months. and make sure it has a filter on the overflow outlet with a dip tube to stop insects from getting into the tank via the overflow pipe. Also keep the stored water at 60*C and make sure the cylinder insulation jacket is properly fitted.
Very good advice from Darren here. Just for OP's information, if your tank doesn't have the components as suggested by Darren, you need to buy a "Byelaw 30 Kit" which contains all these things.
Definitely check what temperature the hot water is set to. Should be 60 C. It seems to be popular to reduce the hot water temperature for eco/economy reasons but if you store water in a cylinder it can provide a lovely warm environment for bacteria to grow. Some of those bacteria are just a nuisance (sludgy biofilms to block pipes) but some can be highly dangerous to health especially when sprayed through a shower head to make a nice aerosol to breathe in. 60 C is too hot for the germs. If you have elderly/infirm in the house and are worried they might scald themselves with 60 C water you can install mixers with anti-scald functions (e.g modern shower mixers, thermostatic bath fillers).
I would check tank in loft had a customer last year all their water smelt apart from mains.when I went in loft there was a dead squirrel float in tank.nice they'd been washing and brushing teeth in that water
Reply to Smelly hot water . Why? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hello, I've just found this forum and wondering if anyone can please help us. We've not long moved into our new home. It's has Johnson and Starley...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
