Snapped stop tap owes
View the thread, titled "Snapped stop tap owes" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
jmsuch
Hope someone can help.
I recently changed some taps and closed the stop taps under the sink. On completion I have turned the tap back on and it would apprear that one has sheared in the closed position. I know this because the handle is turning and my diswhaser is not receiving any water (so it is not the new tap)
Can I replace the centre of the stop tap without replacing the entire unit or are there any magic solutions.
Many thanks
I would say no as when you take the spindle out it will have snapped at the base and there would be no way to pull it out. Even If you could you would need to water off because water would shoot at you for there. You need to isolate the water and replace. Have you got an outside stop tap?
Agree, even if you can get the spindle out by the time you've messed about it's much easier to change the entire stopcock for the sake of £6 or so. If it's a compression one provided the nut threads are the same, just undo the compressions, remove the stopcock and stick a new one in its place. Takes about 5 mins provided you can get at it OK.
The threads in stop taps have changed over the years so a new mechanism may not fit the old tap. When the handle turns it is usually the handle that has stripped. Sometimes the pipework is all iron and it is worth fitting a new washer in a stop tap.
Reply to the thread, titled "Snapped stop tap owes" which is posted in UK Plumbers Forums on Plumbers Forums.
jmsuch,
oilman,
