Discuss Solderless Just for copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any opinions on this stuff, expensive but for DIY one off looks ideal?
As this is a plumbers forum, I would guess that most people would say if you cant solder, either use a compression or a pushfit or get a plumber in. I for one would never risk using something like that as you could end up wrecking a house. Capillary fittings are designed to be soldered not glued
I've tested a copper tube and capillary fitting glue in the workshop. I can't remember the brand now because I threw it away after following all instructions, the glue was not set after even 24 hours. It was still tacky but I pressure tested it anyway and it leaked and blew off at 1 bar.
The glue itself was green in colour. I'd never trust such a thing.
All it is epoxy
I've seen some that's supposedly WRAS approved. But I can't see what's wrong with compression or pushfit if you can't solder.
I recently had to use crimp fittings on another site where no hot works were allowed at all - the crimp fittings were extortion the hire of the crimp fitting tool was also expensive, you can make all the pipework up and without crimping them, change as needed but once they have been crimped and if you have made a mistake theres no changing or altering without stripping it all out and thus the crimp fitting you have just used now becomes useless...
speaking from experience!
get a plumber in to solder your joints otherwise use compression or push fit.
Where did you get your kit from also what were the prices ?
Plumb centre with no account so initial payout was expensive - 15mm - 22mm around Ā£1.80-3
35mm around Ā£8-12
42mm easily around Ā£16-20
Probably could get them cheaper off the net!
R.E.M.'s pipe crimper from HSS around Ā£100 for a weeks hire - because I don't hire much from HSS I didn't get too much of a discount!
35mm around Ā£8-12
In my opinion crimping is a great piece of work. It looks need and stands a lot of pressure.
35mm around Ā£8-12
Have a look at pipekit for fittings or bss if you have an account
Tool hire your looking at 40 a week from bss jaws an extra 10 so 50 a week
You got done mate
Ive just done a whole first fix with crimped fittings, not sure im sold on it yet. Expensive i thought and a pain carrying the geberit kit a long way from the van. Does look neat though. Only used it as it was specced for it
But no worse than carrying your soldering kit tho ?
Maybe for some, my soldering kit lives in my main tool bag though so goes everywhere with me
So you carry it everywhere even if you don't need it ? Lol
Yep, flux solder gas bottle and a rag all lives in my main tool bag
Reply to Solderless Just for copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
