- Messages
- 150
Does anyone have a preference to use solvent weld or compression fittings for waste pipes?
Discuss Solvent Weld vs compression waste pipe in the USA Plumbers Advice area at PlumbersForums.net
solvent weld always
Solvent weld everywhere.
Only exception, I sometimes use a compression elbow in place of a rodding tee when a waste pipe goes into a gully and I feel it would be useful to dismantle to allow clearing of pipework in future and clearing of gully.
You getting Push-Fit mixed up with Solvent Weld?I thought that solvent weld pipes are different to pipes for compression -so is there a special compression fitting for solvent weld pipes?
No that’s not correct.
Solvent weld pipe is different from pushfit pipe, and compression fitting will work with both of them.
All proper plumbers use solvent weld, push fit waste is a bad idea.
I would buy McAlpine for your compression fittings and traps, I’m sure others are ok too but those never let me down.
Reply to Solvent Weld vs compression waste pipe in the USA Plumbers Advice area at PlumbersForums.net
