Discuss Sorry: ecotech Pro 28 filling question.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
We’ve just moved into our new house. The boiler is an ecoTech Pro 28. Identical - or so I thought - to the one in our previous house. It was installed by British Gas two years ago and serviced a couple of mo the back.
I’ve run around the house and bled all the radiators, the pressure is now really much too low (0.7).
Our last boiler had a built-in fill loop behind the cabinet below it. I can’t find a loop anywhere for this one.
From reading on here, I gather I need to buy a loop, and then attach it below the boiler to fill it up. I’m sorry to ask (and I know this has been discussed here before), but can anyone guide me what I need to buy and where I need to temporarily attach it?
The pipework beneath mine doesn’t quite look the same as the other examples I’ve seen whilst researching on here..
Alternatively: if you’re based in Brighton and can help in person, I’m very happy to pay your time.
Unfortunately there’s nothing below the boiler: it’s all tiled in. There’s a cabinet directly below it, no false back or any way to access the pipes from inside there.
However, the kitchen (and tiling and cabinets) is ten years old, the boiler is two years old. I’d thought perhaps I just needed to hook a fill loop to two of the connections on the underside of the boiler (see previous photo). I’m guessing that’s not the case?
It absolutely is a tiled piece of wood.. it’s very securely attached to the rest of the wall though. Never mind, I hoped there was a workaround, guess we’ll start gently demoing!
Can you contact whoever serviced it?
You’ll be surprised at how many silly things like that we all hold in our heads; for instance Mrs Langbrooke’s barkeepers friend is behind the basket of spontex and micro fibre cloths, next to the brasso - and it probably needs replacing in the next couple of months...
Reply to Sorry: ecotech Pro 28 filling question.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I’ve lived in the property for 4 years and anytime the pressure got low (0.8 bar) I would use the fill taps to release more water into the...
3K
A
Hello all, Im wondering if you can help? Ive got a Vaillant Ecotech Pro 28 which was installed 9 years back and has worked like a dream all its...
2K
Hi all I’ve just joined the site as I find myself searching for answers to heating questions and inevitably landing here, reading people’s similar...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi all, I think has been discussed before but I don't think I've seen a clear answer. We have the Vaillant boiler as above and the filling loop...
5K
