Discuss Sparky version of the ddm2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Really ? Is it just a cheap copy I thought they might have given them the rights or something
Bought one once. Never again will I buy anything sparky!!! Never.
Replaced it with a dewalt core drill for 200 quid, the sparky used to take 45mins to core a hole, clutch biting all the time, the dewalt goes through In minutes!!! I used to think it was my core set that must be crap but it was the drill!!!!!
DeWalt D21570K-GB 1300W 127mm Silver Bullet Diamond Core Drill 230V | Corded Diamond Core Drills | NoLinkingToThis
This is what I replaced it with, very good for the price! I normally buy makita but there core is more like 300+ and can't imagine it's any better than this dewalt!
Any problems with the clutch on that I've got the macrist 850 cores
I only drill the occasional flue hole, but no the clutch is good, dosent bite too often & when it does it's alright... The sparky would try to rip your arm off with its sudden JOLT
I've got this one and the clutch is forever catching! I reckon a baby could hold it! It winds me up a treat.
Anyone using this core gun ?
yes, got one, and like anything buying a tool fit for the job makes it easier. I had the smaller sparky, 2 in fact, worked ok and wore out quickly, as too small for the job. the ddm2 copy is fine, only problem is your really need it in a mount or youll end up spinning with it, it is heavy, it does have a high prm and with decent core drill bits it will belt through walls no problem. Just because the smaller ones wear out dont walk away from this beastie, available from big red tool box, make sure your clear on whether you want 240 or 110 as their supplier is a ****, I got a 110 and had to chivvy them for months to give me a free transformer, won in the end :)
marchrist ddm1 is like the small spaky and will **** you off in the end, ddm2 or hilti is the way ahead
Reply to Sparky version of the ddm2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
