Discuss storing gas bottles in van in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I go on holiday for a week I wondered if its usually ok to leave gas bottles in the van or if the weathers hot/sunny could the heat cause a problem? Same for flux. Thanks for any advice
Just make sure everything's locked and secure. And don't forget to wear protection yourself. Have fun!
Who cares. If you come back and find yer van lying upside down in the next door neighbours drive well thats what insurance is for but check the wording before you leave ;) lol
He sprayed it onto his dashboard though, gas bottles stored in the van with torch off are fine and so is the flux
Mine has always stayed in the van, not had an issue yet
If your van went on fire, for any reason, - the firemen would consider gas bottles inside your burning van as highly dangerous. Basically a bomb.
But what can you do other than have signs on van stating Propane or whatever gas you carry.
I use propane as a refrigerant R290 Ive never even considered taking it out of the van for fear of it getting to hot
Reply to storing gas bottles in van in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
