Discuss Stripped Gland nut on stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I Stripped the gland nut on stopcock like an idiot. I did not pack the gland properly and kept tightening the nut to stop the drip, by doing this i destroyed the nut.
Do i have to freeze the pipe in order to replace the stopcock or is there a way of removing the gland nut?
At least there's no water exploding out of the pipe!
I presume you mean the incoming stoptap ,if so you should have a external stoptap that you can hopefully turn off and replace the inside one
Hi all, Its a council estate so i can't turn off the mains. Would the only option be freezing the copper pipe?
also thanks for the fast replys :)
I looked for where the pipe came from and theres no stopcock. It just goes through the building and branches off to each kitchen/flat.
How will the water be turned off in an emergency
Call the water undertaker & ask them come & turn it off. Then when they arrive watch where it is. Simple
So there will definalty be a mains stopcock somewhere in the flat? I can only find the sink kitchen, bathroom sink/bath and toilet system stopcock
Reply to Stripped Gland nut on stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
