Discuss stuck in cooling mode in the Central Heating Forum area at PlumbersForums.net
My air/water heat pump is stuck in cooling mode. For whatever reason it's parameters have changed to cooling only and turned itself to standby mode. I can't change the parameter now and the machine wont let me turn it on. Any Ideas?
Reply to stuck in cooling mode in the Central Heating Forum area at PlumbersForums.net
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating...
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
