Discuss Stuck plastic wingnut in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tony74
Hi!
I have a plastic wingnut joining the cistern to the toilet that is totally jammed and in an awkward position. i.e. I cant see it as the loo is close to a wall. Managed to get the other one off with a hack saw and brute force but I just cant get the purchase on this one with the angles available.
Is there a way to get this off that I am missing? (has been well soaked in WD40).
Tony
do you have a wing nut key?
you can get them in toilet seats sets from wickes foc there about 3'' long.
or you can buy the yellow pro versiion from monument tools.
otherwise get a tube, grind a slot in it and use that.
its all about purchase angles
Thanks for all the ideas! I will be trying them now...
Part of the problem is the whole bolt turns and getting enough purchase on the head to apply brute force to the wingnut
He's trying to get the cistern off rather than the seat. A seat that can't be undone properly, smashing the hinge off is a great idea but not on this job.
Think he means the dome head inside the cistern
Reply to Stuck plastic wingnut in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
