Discuss Tap back nut spanner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know if the metal handle/pole that comes with the back spanner has a name if so what is it called and where can you get one from?
Would think it will be refered to as a bar, sorry that`s my only input.
Tension bar? Leverage Bar? Tommy bar?
Old screwdriver?
Or just buy a new set with either with more sizes or a cheapish set just for the bar
Length of silver steel from an engineering workshop will do it.
tommy bar, and there soft and bend like owt.
get sone re-bar to fit or weld a handle to it
Reply to Tap back nut spanner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Did anyone watch Britain's Got Talent last night? There was a Plumber on from Stockport called Darren who bottled it last year but did his...
