Discuss Tap design pressure... in the USA area at PlumbersForums.net
Hi guys, happy new year to all.
Anyone able to explain to me the cons of fitting taps designed for high pressure on a gravity fed supply?
I'm currently doing my bathroom, but don't want taps designed for low pressure as I'm planning on having my cylinder swapped out in a few months and going mains pressure everywhere.
If I install high pressure designed taps (non thermostatic) am I right in assuming that they'll work fine for the time being as an interim measure?
Thanks!
They'll work but you could probably p faster. Depends on current height of header tank above the taps.
Not a lot unfortunately, probably a couple of meters max above the level of the taps!
Pee flow is fine as a temporary measure, been staying at the mother in laws where the mains pressure is so bad that you have to start the bath 15 mins before you want it...
At least it will be a constant reminder to get the cylinder swapped out
Not sure how far away your mother is but might be worth testing your mains flow and pressure to ensure they’ll supply your house adequately with an unvented system.
We're all good for it here, really good mains pressure on a fairly new estate.
The in-laws place is a Victorian semi at the top of a hill, supplied by original lead pipes from the street, utterly hopeless!
Reply to Tap design pressure... in the USA area at PlumbersForums.net
