Discuss Taps/shower dripping when another is turned on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RichCroker
I've had an issue come up that I'd welcome some advice on.
Whenever I turn a tap on now (e.g. my bathroom sink), the other taps/outlets in the flat then also dribble (to various degrees). There are only a small number of outlets (1 bathroom sink, one shower, and one toilet).
I don't think it's a washer issue, as it happened overnight and it seems inconceivable that the washers have all gone within hours of each other. I have had issues with my boiler pressure (crud popped the bag that stabilised it), and am getting that fixed, as well as the power shower which had issues with the hot water (not sure whether those two are linked).
Any thoughts welcome. Thanks,
Rich
could be a few things
high incoming pressure (water pressure)
washers starting to go, and the increase when you shut a tap makes them drip/ pass
expansion (no where for the water to go due to fast shutting taps / 1/4 turn)
Reply to Taps/shower dripping when another is turned on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
