Discuss Thanks for the replies in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Thanks all for your replies. I have settled for a lesser-of-two evils option.
I cut the copper coming from the stack elbow back a bit further, and have glued (desperate times) a solvent weld elbow onto the copper using a large quantity of quick setting glue. The rest I have managed to get level enough using fittings. I will wait for the glue to dry and thoroughly test. If the one potentially weak point works then I'm out of trouble, if not it'll be back to the drawing board.
Reply to Thanks for the replies in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Evening all, I’m currently in the process of refurbing my house, and have opted to wet UFH for the whole of the downstairs. The upstairs will be...
B
Hello I’m not going to explain this very well but I will try my best. I’m planning on installing a kitchen sick by myself with no plumbing...
Deleted member 120897
I know this is a bodge but the previously 'glued' repair has held for 12 years. This was originally installed by a large gas company when...
2K
