Discuss The boiler will not turn off . in the Oil and Solid Fuel Forum area at PlumbersForums.net
M
MetMan
The boiler (480k, serviced every year) will not turn off at the end of the 3rd timed cycle each day, even though the green 'on' light is out. This happens when set to 'heat and hot water'. Switching to 'hot water' only, turns it off. Engineer called three times and has replaced the control panel and the mid position actuator, to no effect. The cooker side is fine.
Reply to The boiler will not turn off . in the Oil and Solid Fuel Forum area at PlumbersForums.net
Rayburn will not turn off at the end of the third cycle each day when set to 'heating and hot water', even though the green 'on' light is out.. Switching to 'hot water' only, turns it off. Engineer called and replaced the control panel and mid position actuator - no effect. It turns off OK at...
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
Hi, looking for some advice. We have had an issue with our boiler of late and recently had a 3 port actuator replaced. What’s happening now is when we turn the water and heating on by the control panel the boiler cuts out after a couple of minutes. We opened the valve of the actuator and now...
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the boiler has started to stay on all the time. My usual engineer took a look at it and advised me to contact the manufacturer. I then had an engineer from...
Bad leak inside bathroom walls at floor for three days. A gallon every hour. Shut off water for a few hours and leak stopped. Turned water back on and leak has not come back. What happened?
