Discuss Thermalite blocks . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
Whats your most reliable method of fixing to these bloody things. I normally use a No. 10 screw with a red plug and nine times out of ten its OK but not today I am all ears
Brown and a 10 screw or 12 if it's 4" long
Depends what your hanging, If its a boiler then use the bolts provided is usually fine. Brown plugs and screws works for everything aswell.
Brown plugs and 10 or 12 screws depens on what your hanging on it could use a chemical fixing . cheers kop
Probably the red plug doesn't have enough diameter to get a good enough purchase as a brown. But my preferred rarely fails and I hate the crap that boiler manufactures supply with there boilers to use as fixings
Just bought some Fischer Duofix plugs, can be used in multiple structures. Seem pretty good.
never use anything but Brown plugs have done for more years than I can remember never had a problem
Two brown plugs in a 7mm hole and a 3-1/2 10 or 12 screw
I have had to go straight through before using long bolts into the external brickwork.
Reply to Thermalite blocks . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate to sort this chaps. I’ve installed a boss strap today and the bloody thing is leaking. I glued it as normal and cleaned it up so I’m...
I bought the a bleed valve from S****fix about a year ago: s****fix.com/p/radiator-vent-blanking-plug-nickel-2-pack/40972 It worked fine...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some...
I am not a plumber, but very fluent in residential plumbing. My Daughter has a building in town. There are 2 Woodford wall hydrants. Neither one...
