Discuss Thermostat (manual, M30x1.5) does not fit on radiator (too large) in the DIY Plumbing Forum area at PlumbersForums.net
Hi, I bought a M30x1.5 thermostat and was hoping to fit it onto the radiator (there is currently no thermostat attached), but it does not fit (the thermostat connector is too wide, see photos). Do I need an adapter or something, or a different thermostat? Thanks!
Reply to Thermostat (manual, M30x1.5) does not fit on radiator (too large) in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
