Discuss Thermostatic Valve, fit to Flow or Return? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am trying to install a new single vertical radiator and need to know if matters if the thermostatic valve is connected to the flow or return pipes.
It depends which valve you have , but most nowadays are bi-directional so it doesn’t matter.
However.
On a vertical rad quite often the direction of flow is critical - it should tell you this , but it doesn’t matter if trv is on flow or return.
Recommend to fit on the flow pipe
Reply to Thermostatic Valve, fit to Flow or Return? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
