6397Luke
Can anyone help? A friend of mine has 2 CWSC in her loft. The two are linked by a 22mm pipe near the bottom of the tanks and both have independent float valves.
I'm told that the second tank was fitted to enable the installation of a shower pump?
Anyway, only 1 tank has an overflow which now continuously pours out water. I've replaced both float valves but this hasn't solved it but when I isolate the feed to the tank with no overflow, the second tank stops overflowing.
This tells me that one tank is casuing the other to overfill, however replacing the float valves hasn't sorted it and I can't understand why or how to solve it?
Any ideas will be greatly appreciated?????
Thanks.
Thanks.
