Discuss This looks handy in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I looked at these too if you go to his website off ebay project21designs.com he makes some cool consumable holders too
Exactly. This is why I was trying to come up with some cool waste fitting storage solution other than having them all in two boxes.
You've changed since you got that new van. I don't like it one bit!
I've only become organised I'm still a deviant
Is it plastic or metal ? If plastic be worried about snapping it
4 22mm open clips spaced correctly and screwed into the racking or back door. Job done. Clips in and out easy and never moves! Top tip # 1
Guides always stay in the soldering box along with about 4 15mm slices, 4 22mm slices and 3 28mm slices! There's only one of each I use but always good to have a spare even if the disc looks like a toothless crack head. I really must service them one day!
Jon
Reply to This looks handy in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
