Discuss Thoughts in the Gas Engineers Forum area at PlumbersForums.net
Looks fine to me ideally would of put it inline with the overhang but it’s got enough clearance above
Is there no concerns regarding the frailty of glass? What would happen if the window was to be smashed leaving an unsupported flue and potential issues this would cause especially if installed through a bedroom window?
If the window smashed there'd be plenty of ventilation. :)
I take your point, glass isn't ideal but it isn't hazardous either and lets face it if the window broke you'd be extremely daft to keep using the boiler.
Having said that I think I would've used a plume kit.
Same thing what happens if you put a bag over the flue it’s all what ifs
Reply to Thoughts in the Gas Engineers Forum area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
