Discuss Thread Locking Glue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
I need to remove a shower cartridge but there is a centre piece to it which is threaded and comes out, instead of turning the entire cartridge.
I read up on loctite 243 but it says the thread can still be undone with hand tools.
I need something that literally sets solid and doesn't undo.
Any ideas?
Well, typically with tools anything can be undone, but 243 is medium strength.
Does the thread locker need to seal against water also?
If so, can try Loctite 577, it's superb at thread locking.
Loctite 620 has a lot of strength too.
Another high strength thread locker is 270.
Think they are referring to a sharp wack on the spanner to undo which most if not all will undo with, any temperature involved?
Any ideas?
Trying to picture this, are you sure there is not a specific tool that is used to unscrew the outside body of the cartridge rather than the part you are currently using to try and unscrew the unit. Just a thought as obvisouly can't see what you are seeing.
Nah, my boss had the same valve not too long ago and the manufacturers said this is the only way - stupid I know
solder it sorted
Not sure it'll be strong enough :/ plus I have to screw it back in while the solder is still hot enough before it sets and it's a bugger to screw back in quickly
spindled if so dont :) and epoxy it in
Any ideas?
Not sure if your sorted or not but I've had a thought.
If the center section that is unthreading is not pressure retaining, drill a 3 or 4mm hole into were the threads intersect about 4mm deep. Then push the shank of the drill into that hole and it will lock the threads while you screw the whole unit out.
Very interesting idea!!! Not been sent back to the job yet. If all else fails I'll def give that a go.. Cheers mache ;)
Reply to Thread Locking Glue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
