Discuss three way MID valve (drayton) always hot? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi..
My central heating had stopped working although till had hot water... after a search and finding the manual lever on the Drayton MID valve restored heat to the radiators.. I fitted a new one...
I swapped the coloured cables one by one as the old one was in place so as to know I had the same colour coding.. On filling up the systems and switching on and running it.. it worked! Operated straightaway to the proper marked lettering on the side of the switch when selecting W only or Heating only or both (M)
However the plastic casing around the electrics on top of the brass valve is very warm. I'm from another electrical engineering job and i remember that some motors (elevators) used to keep power on as a means to keep things closed.. they ran very hot.
I don't know enough about this device to say if it doing the same thing.. seems a waste of energy to me.
It is an MAI/679-3
This one is a snap on head version (easily removable head)
Appreciate your thoughts please
yes if the heating is on the heads do become warm as there held open / shut also you will get a bit of bleed through via the valve body
Thanks very much for your reply Shaun..
Good to know... I'm looking at a magnetic filter now but only have about 8" of 22mm copper return pipe free above the boiler case above the boiler :(
Fernox omega should fit
Reply to three way MID valve (drayton) always hot? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a fully pumped heating system fitted with a Drayton MA1 diverter, after the summer run the heating stopped coming on, so I replaced the...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
Hi, i am replacing a 2 port z5 drayton valve with a 3 port mid position drayton. Can anyone please tell me what changes i have to make to the...
Deleted member 120897
Hi I’m new here and don’t know a thing about plumbing so be gentle on me as I am also going to ask a possible dumb question, this summer I turned...
