Discuss Timer and Thermostat Update in the DIY Plumbing Forum area at PlumbersForums.net
N
Nicholas Sims
Hi all,
I have a mechanical timer (5 wire not including ground) by the boiler for heating & water and a thermostat in the living room.
The timer keeps missing switches so not coming on/off automatically. I could replace it like for like but I'm considering removing it and changing the thermostat to control everything from there.
Is it a simple task with some wires joined together or is it a big rewire that requires a professional?
Thanks in Advance.
You could chance it for a new timer easy enough but depending on your knowledge you could upgrade to an all in one eg nest etc
Reply to Timer and Thermostat Update in the DIY Plumbing Forum area at PlumbersForums.net
